Dream Home - Ispiri 12mm Americas Mission Olive Laminate Flooring Logo
A
Anonymous Posted on Jun 29, 2014
Is Pergo the same as laminate? - Dream Home - Ispiri 12mm Americas Mission Olive Laminate Flooring
michael
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 22, 2022
michael
Contributor
Level 1:
Answers
Questions
0
Helped
2234
Points
9
Pergo is the name of a laminate manufacturer. They were once the brand name that most people recognized. However, over the last several years, many other companies have developed laminate products. Pergo is now commonly sold in most box stores. We have a niche floor covering forum page that talks about this, as well as many other topics. You can find us here: Best Flooring Forum ' BEST RUG PRICES'
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 23, 2019
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
2423
Points
6
Pergo is a brand of flooring. It can be either engineered wood or laminate.
L.A. Rankin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2019
L.A. Rankin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
844
Points
It’s a brand name of it. Pergo actually invented laminate flooring in 1977.
Marks
Level 1:
Habit-Forming:
New Friend:
  • Contributor 16 Answers
  • Posted on Oct 20, 2015
Marks
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
16
Questions
Helped
7923
Points
79
Pergo is a brand of laminate flooring. This flooring option is one of the premium laminate flooring choices.Pergo flooring is easy to maintain and simply use a dust mop or vacuum hard-floor attachment to remove dirt and dust from the floor's surface.
FLOORING 101
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Mar 02, 2015
FLOORING 101
Contributor
Level 1:
Welcome Back:
Answers
19
Questions
0
Helped
6668
Points
55
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
1helpful
How to remove dried Behr Premium Plus Ultra Eggshell enamel from Pergo flooring?
Hello, Natalie -
You may find the information on this web page instructive:
https://mattthepainter.com/safest-way-remove-paint-laminate-flooring
If you hired a interior house painter or painters to do your painting job, I hope you reported the dried paint drips on your laminate flooring to the painting business. Perhaps, the painter / painters will offer to hire a professional cleaning business such s Servicemaster or Servpro to remove the dripped paint from your flooring.
Best wishes.
2answers
My room is 13 x 12 how many square feet do I need?
13 x 12 = 156 square feet. However, they recommend getting 10% more to allow for staggering seams, trims cuts, and possible defective boards, so you should get at least 170 square feet.
2answers
How do I install a floating floor
Floating means you do not use Glue...You should put the mat down that they recommend over the sub floor prior to installation
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
I use it on a laminate floor { pergo } and it shows streaks every time. It looks terrible when I am done.
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
I followed all recommendations from Pergo in cleaning my floors. None of them work, all I get is smears. I used the vinegar, the amonia, nothing, please someone end my nighmare.
Since, you've already tried to clean with almost everything known to man. I can't help but wonder if finish on your Pergo floor may be at fault. Perhaps, you can get a factory representative form Pergo or the store you purchased from to do an on site inspection. After all, the finish is warranted against defects in workmanship.
At this point, what ave you got to loose?
Can this be used on Pergo Floors?
Yes, It will work great on Pergo floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Top Dream Home - Ispiri Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Dream Home - Ispiri Building Material Expert? Answer questions, earn points and help others
