Toshiba REGZA 52RV530U LCD TV Logo
A
Anonymous Posted on Jun 29, 2014
Removing stand from a lg 42lc7d - Toshiba REGZA 52RV530U LCD TV
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
How do I replace the bulb on an LG 42LC7D
first you need to remove old bulb there is model no menstion on the top side.please check and replace with same no.
My Lg 42lc7d 42 inch flatscreen tv has no sound
1- check all the cables that are hooked up to the TV 2- try to get audio to and external speakers or home theater (to check the sound card). 3- if the step # 2 don't work either you have a bad sound board on your TV. 4- opn the TV try t get the part # of the board, and replace it
What hold the stand in place? Where are the bolts?
The screws are usually centred in the lower middle part on the rear of the TV, there will be four deep set coutersunk holes where the screws can be found. The stand is fixed to a pedestal arrangement which fits to the underside of the TV.
2answers
Cuts off
Most likely the power supply board.
Lie the tv down on a bed and unscrew the back. Its only about 9 screws around the edge and look at the power board, on the left, see if theres any burn marks.
I have a brand new board I bought the other day for the same issue but before I replaced it, stupidly, I checked with LG and turns out mine is still under warranty so I'm stuck with a new board.
Let me know if you want it. I'll match any price you can find online.
4helpful
Replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
1helpful
Missing LG pedastal
You can find a replacement base stand assembly for that model (42LC7D) at the following link:
LG 42LC7D Replacement Part Base Stand Assembly
Model # RU52SZ30 may have no stand / pedestal available.
13helpful
3answers
Replacement table top stand for lg tv
Cracked table top stand for 42LC7D flat screen
14helpful
2answers
Replacement lcd screen
I have broken Screen how or where can i replace it? (model 42lc7d)
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
