Homelite 'Yard Broom' Leaf Blower Logo
g
gail nielson Posted on Jun 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Homelite26b ran one day and will not start the next day I have changed the spark plug and bulb
john andrew manchook
Level 3:
  • Master 755 Answers
  • Posted on Nov 28, 2014
Master
Level 3:
Answers
755
Questions
Helped
284992
Points
1983
Dump the fuel and mix up a fresh batch with some fuel system cleaner in it. You may have a partially blocked fuel passage.
If a system cleaning doesnt work check the fuel lines for damage. Many times the fuel line in the gas tank splits and you only get fuel when the level is above the break!
Be safe and good luck!
2 Related Answers
Anonymous
  • 76 Answers
  • Posted on Dec 28, 2008
SOURCE: homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
roadtech7
Matt Olenzek
  • 297 Answers
  • Posted on Feb 06, 2011
SOURCE: i need a primer bulb
Hi, most small engine shops will have one. If you remove the old one, you can take it along and they can match it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Testimonial: "I REMOVED THE OLD ONE AND TOOK IT TO THE REPAIR SHOP,GOT A NEW ONE. THANK YOU."
1helpful
Won't start, good battery, lots of spark,good gas, ran one day and not the next.
Hi Sandy:
Hmmmmm.
Something must have happened.
Back to basics.
Pull plugs, check for hot blue spark.
Plugs wet? Fouled?
If dry and spark then no fuel.
Drain/flush carb.
Change fuel filter.
Think of it as entertainment.
Cheers,
Happy New Year.
2003 freelander, no spark. Changed cps and checked fuse and relays. Still no spark at plugs. Cranks fine. Ran fine and next day no start. Any help??
Check your distributor, particularly the cap and the wire that goes into the center of the distributor cap. Could be a loose/bad wire or a bad distributor.
I have a 1996 Oldsmobile cutlass supreme and it was running alittle rough but was running. It sounded like it was missing alittle bit. It stalled on me at a red light but started back up and ran good. The...
The first thing to check is the ignition timing then the spark plug gaps. There are specific settings/size for the above and must be correct for the car to run smoothly.
1988 Plymouth Sundance no spark
if there is a brain box on firewall there is a white ballast resistor next to it that has quit working replace ballast resistor.
3helpful
3answers
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
2answers
1helpful
1998 mitsubishi mirage 1.5 liter 5 speed wont start
If you have spark, try changing the fuel filter. If you don't have spark, get back to me.
88 tercel no spark, cranks fine
Unless you have the equiptment to check the microprocessor, I believe that is next.Sorry
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
