Samsung HLR5067WX 50" Rear Projection HDTV Logo
A
Anonymous Posted on Jun 30, 2014
Tv freezes and you have to shut it off or keep unplugging it to get it to turn back on sometimes waiting for 15 minutes
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Apr 01, 2007
SOURCE: TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Anonymous
  • 149 Answers
  • Posted on Sep 24, 2007
SOURCE: Loss of Power
You might want to unlpug the powercord for the night, then plug it back in the next morning. Some times that can help reset things. If that still doesnt do the trick, you might have a faulty power cord. If it does this with every source you hook up to your TV then that would be a sign that its something in the set vs. your external source.
Anonymous
  • 4402 Answers
  • Posted on Jan 30, 2008
SOURCE: screen freezes, won't shut off
digital freeze. Usually signal related
Anonymous
  • 3 Answers
  • Posted on Apr 27, 2008
SOURCE: My Samsung 50" HLS5086W wide screen tv keeps shutting off....
I have a Samsung DLP 61". The TV continued to turn off with no indications from the panel. I did some tests and determined the TV was not getting enough air circulation due to its poor fan inside. I installed a 110v computer fan on the outside of the vents on the rear of the TV to **** the heat out. Worked great and I have never had a problem since. Need further help or pictures let me know
John
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2009
SOURCE: i have a hl s5087w 50in tv and it keeps shutting
Look in the back of the set. You will find a Black Lamp Door with one screw at the top if your set is black. Remove the Lamp Door carefully. You might hear a click, If you do then reinstall the Lamp Door and tighten the screw. If you do not hear a click don't worry, replace the Lamp Door.This resets the Interlock Safety Switch. The switch gets hot and opens the circuit. Any time the rear case is removed you must do this as the rear case does not engage the Interlock Switch properly. If the tv comes on and you have a picture wait a while to see if the set turns back off, If it does then you might have a bad a Lamp and or Lamp Ballast. Take the Lamp out through the Lamp Door and look at the Front Galss. DO NOT TOUCH THE GLASS AT ALL!. If you see shattered glass, you have a bad lamp. If you do not replace the Lamp any way because the Lamps for this Model can look good and still be bad.
Samsung un55es7550F keeps shutting off shortly after being turned on
Please unplug the tv for 30 seconds before powering on the tv again. Also, please check that the "auto power off" features isn't on (Settings >> General >> Eco Solution >> Auto Power Off >> Select Off)
Thank you.
1helpful
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Imac g5 is so noisy
Fan sometimes get stuck on, I won't bore you with the technical details as to why or the terminal command to fix. Just do this...
Shut down. Unplug the power cord from the back of the tower. Wait 15 minutes and plug it back in. Power up, it should have reset it.
The fans are "smart", some of them are designed to run only as needed, sometimes they get a little tangled up in their own underwear.
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
2answers
Fujitsu P50XHA10E
Maybe inverter board is getting ready to go out. Only suggestion is to reset tv by unplugging from power source. Sometimes this will clear up strange problems like that. Best I can do for now.
2helpful
2answers
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
