Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
A
Anonymous Posted on Jun 29, 2014
One oven not working
Hi,one of the ovens do not work it just blows out cold air,it has no heat
2 Related Answers
Danny
  • 160 Answers
  • Posted on Dec 18, 2009
SOURCE: Main oven fan is working but not hating up
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Anonymous
  • 40 Answers
  • Posted on Apr 11, 2010
SOURCE: the fan work on main oven but does not heat up it
sounds like the heating element, hope this helps
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 • Ovens
Ec600 dodlm model the fan oven is only blowing cold air
check for blown oven fuse. replace heating element in the oven
Jan 30, 2015 • Ovens
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 • Candy Ovens
Cold air blowing out of oven & oven not heating up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 14, 2011 • Ovens
Oven blowing cold air not heating up but grill is working
You need to replace the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Microwave oven will not heat? Could it be a fuse. The fan makes a louder noise than before it stopped heating. One side blows hot air the other side blows cold. Not sure what to do
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Electric oven tripped my electricity a day ago and now the fan oven just blows out cold air
It is most likely that the oven heating element has failed. You will need to have it replaced
Normally the heating element is located around the circumference of the fan assembly and when it is working it glows red. You would see it if it was on.
Jan 11, 2010 • Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 • Ovens
4helpful
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 • Ovens
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
