Question about Casio JF-100TE Calculator
How do I change the tax rate? - Casio JF-100TE Calculator
SOURCE:
SOURCE: casio MS-120TE tax rate
Found this on the casio site worked fine on my ms-120TE
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds until set and a 0 is displayed
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
this is the link:- http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE
Posted on Apr 01, 2008
SOURCE: How to change tax rate on Casio MS120TV
I found the solution listed against a different CAsio Calculator.
It was .. Press AC, then hold 'set' for a few seconds then press 'Tax+' , input new tax rate then press 'set'. Job Done
Posted on Jan 07, 2009
SOURCE: Tax Rate
1. Press the AC button to clear the screen
2. Press and hold the Set % key until Set appears
3. Press the Tax+ key
4. Type in your tax rate (including decimal point) you wish to calculate
5. Press Set %
Posted on Mar 01, 2009
taran_2005
  • 10515 Answers
SOURCE: change the tax rate on calculator on MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Posted on Mar 23, 2009
SOURCE: how to set tax rate
Hold down the Rate Set button for a few seconds until it flashes. Set your rate in % so for 5% do 5 or 12.5% do 12.5. Then press Rate set again. This should sort ya out.
Posted on May 28, 2009
HOW DO I CHANGE MY TAXES RATE?
Please clarify the question. If you mean tax withholding rate, change the number of exemptions on your W-2. That won't change your tax liability at the end of the year, but will change your take home pay. If you mean actual tax rate, then you need to change the amount or source of your income, or change your tax deductions. Regarding source, I mean earned income vs investment income.
Jan 22, 2015 | Office Equipment & Supplies
How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
Mar 05, 2010 | Casio Office Equipment & Supplies
How to change the currency and tax rate values on
Press the red "ON" button and hold it. Press and hold the "% (SET)" button and hold it. Release the red "ON" button. Continue to hold the "% (SET)" After a few seconds, "SET" will appear at the top of the screen. Press the "TAX (TAX RATE)" button. "M TAX SET %" will appear at the top of the screen. Your current tax rate will now be shown in the display. Enter new tax rate and press the "% (SET)" button. Your new tax rate is now set.
Jan 16, 2010 | Casio Office Equipment & Supplies
CHANGING TAX RATE
press AC
while holding AC press SET/%
while holding SET/% release AC
your screen should read SET on top
now press TAX+(TAX RATE)
enter tax rate (7.25 or 8.75) what ever the tax rate
then press the SET% again,
you just changed your tax rate
Dec 18, 2009 | Casio MS-80TV Scientific Calculator
How do I set the tax rate on LS-80TS?
Oct 06, 2009 | Canon LS-100TS Calculator
Casio fr-2650 plus calculator
cliff notes:
hold set% button
hit tax+ button
hit set done
Apr 05, 2009 | Casio FR-2650Plus Calculator
Change the tax rate on calculator on MS-8TV
cliff notes:
hold set% button
hit tax+ button
hit set done
Mar 23, 2009 | Casio Office Equipment & Supplies
CANNOT SET TAX RATE ON MY CANON MP11DX
To change the tax rate on the Canon MP11DX (and most others):
Slide the "GT" button to "RATE", enter your tax rate and hit the "TAX+" button. Once changed, slide the "GT" button back to the "ON" position.
Oct 23, 2008 | Canon LS-100TS Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Casio JF-100TE Calculator Logo
71 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
