JVC 46" 1080p FHD LED TV Model LT-46N530
SOURCE: TV screen went dark, but sound still there.
your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
SOURCE: JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs. After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support. They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables. So far, so good.
SOURCE: DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
