Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
A
Anonymous Posted on Jun 29, 2014
How can i solve the problem of grating noise when flushing toilet
1 Related Answer
roberthig924
Robert Higgins
  • 30 Answers
  • Posted on Sep 16, 2012
SOURCE: masticator toilet blocked with hanging toilet freshener
It will dissolve however it will take many days you can't wait so you need to go rent or buy or borrow small rooter route to get it out. It's not a bad fix so don't let someone tell you different. You can fix your self. Good luck.
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
When I flush the toilet it makes a gurgling noise what is the cause?
Probably a small blockage. Plunge the toilet until it flushes quietly. That, or you need more water in tge tank. You'll have to adjust the water flow. I'd say you have a small blockage though...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 • Taylor Home
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
1helpful
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
Our toilet has a much louder flush than before. Water is not constantly running. What is causing this and how can it be fixed?
Have you tried putting a pressure raducing valve before the toilet? the noise can sometimes be cursed by high pressure.
2helpful
2answers
Grinding motor will not stop
my son put a wet wipe down the toilet, now it makes a loud grinding noise when flushed
3helpful
Noise of flush water
You have two issues inside of the toilet tank. The holding down the button is caused by your chain not being tight enough from the handle to the flapper. Take the slack out of that and replace the flapper. The second is that you need to replace the fill valve. This is what is making the noise when the tank is being refilled, and will have to be adjusted after it is installed.
Please remember to rate this.
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Top Saniflo Home Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
