Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely.
Set the controls to the first wash cycle, and then try each water temperature setting.
If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have.
If hot works but cold doesn't, or vice versa:
1) Be sure both the hot and cold water faucets are turned on.
2) Be sure the supply hoses are not kinked.
3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets.
4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves.
5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
