LG 24 in. LDS 5811 Built-in Dishwasher Logo
R
RAELENE Posted on Jun 29, 2014
My dishwasher will not work
My dishwasher is not working. All the lights on the front are working but it will not start.
loky07
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 30, 2014
loky07
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
2560
Points
21
Check all sensors / latches on the door and frame. If they are not aligned or if there is any debris this could cause the dishwasher to not start but to still have power.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 • Dishwashers
Dishwasher lights turn on but doesn't start
it will most likely be a door switch issue, to test it you need to remove the front door panel and bridge out the switch, if it works then you need to replace the switch,
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
2helpful
2answers
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Start light is blinking
It appears that your door switch is intermittently working. Make sure that the switch clicks on and off when you gently press on the release door lever. It you don't here a distinct click sound then you'll have to go into the door switch and do a little filing on the plastic bar so it does not bind with the depressing of the switch. It is very simple to take apart and put back together.
Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Jan 25, 2008 • Dishwashers
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
