SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
SOURCE: Y510 Inductive Touch Panel Opens Win Media Player Automatically
Hi there
The Hotkeys only work exclusively with windows media player.
Good luck and thanks for using Fixya!!!
SOURCE: Lenovo Ideapad Y510 c drive full but d drive shows as empty
The cursor jump is probably because your arm or part of your hand is getting close to the touchpad.
I have the same problem.
You can toggle touchpad support by holding down the 'Fn' key and hitting 'F8'. (Fn+F8)
Don't forget to turn it back on when you want to move the mouse.
In regards to "local disk c:" being full. It sounds like your drive is partitioned into two logical drives.
You can use two methods in gaining space on C:.
The first option would be to move some of your documents from the C: partition to D:. (If you continue to save all of your files to C:, it will become full again.)
The second would be to re-size your C: partition using a tool such as "Partition Magic" in order to allocate some of the unused space on D: to C:. (This may take some time to complete. Make sure you are connected to AC power, you do not want your computer to go to standby or hibernate while changing partition sizes.)
Hope this helps.
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: lenovo laptop ideapad numeric keypad is not
You can go to any service center (or) the dealer for this problem.
