Black & Decker String Trimmer Cordless 12" 18V Logo
A
Anonymous Posted on Jun 29, 2014
Black and decker self feed ns1118 is not working
1 Related Answer
Anonymous
  • 183 Answers
  • Posted on Apr 28, 2009
SOURCE: auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
3helpful
10helpful
2answers
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
1helpful
Auto feed will not work
70helpful
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Black & decker grass hog trimmer
if the white lever under the spool is broken, you can do it be your self. parts cost very cheap
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
