SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
SOURCE: fisher@paykel Intuitive eco comes up with code 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments:
Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
SOURCE: i have an Intuitive eco and it wont drain error 37
Hi just found your posting.Do you still require help?This problem should be simple to rectify.The fault is called PUMP BLOCK ERROR.Please reply and I can guide you throe the repair of the machine.Sorry for taking along time to answer.
SOURCE: fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
