I need instruction manual
Good morning
if you go to manualsonline you will undoubtably find the one you need. Follow the instructions. Free User Manuals and Owners Guides ManualsOnline com
kolbrun
SOURCE: Hitachi 5.6 cup rice cooker
Try Kitchen.ManualsOnline.com and search for Hitachi. Hope this helps!
SOURCE: Hitachi RD6106 10-Cup Rice Cooker
The Hitachi has notches on the inside of the pot. You put your rice in the pot and than start adding water until your water level reaches the notch labeled 7. Remember that the rice has to be inside the pot when you start adding water so that you will have the correct amount of water for the rice you're cooking. It doesn't work the other way around. Rice in pot than add water. But usually the average cup that comes with these rice cookers only holds 3/4 of a cup when you fill them to the top.
SOURCE: User Manual for RD-5083
Here is your manual
http://kitchen.manualsonline.com/mdownloads/0948a51b-dab6-4101-b399-80a59ac81ad3.pdf
Good luck and please rate
SOURCE: Hitachi Rice Cooker/Steamer RD-5083. Need new
hi, I'm looking for the user's manual and found your question.
You can fix it using a piece of wood and screwing it with a Stainless Steel sheetmetal screw (like a #6x1/2"lg ss)
You can also painted if you like it.
SOURCE: I have the plastic measure cup that came with 10
Usuualy the rule of thumb for rice is one part rice, two parts water. so if you want to steam a cup of rice, add two cups of water.
Here
is a tip that will help you figure out about using a rice
cooker...
How
much Rice and Water go in the Cooker
heatman101
