Baseball & Softball Logo
A
Anonymous Posted on Jun 28, 2014
What is Avg wt. wht. Female age 73 height 5'1" tall
NOEL
Level 3:
Top Expert:
  • Master 8,606 Answers
  • Posted on Nov 05, 2017
NOEL
Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322255
Points
68630
1 Related Answer
tombones
  • 3567 Answers
  • Posted on Aug 12, 2009
SOURCE: seat height
What is your question? Just get a bike that feels good to you.
How tall is Kurt Sutter?
Kurt is 5'10". As a reference, look at him beside Chucky and note the heights of both and then Chucky to the others. Once you have an actor's height figured out, the unknowns become easier for others heights.
Im34 years old and my height is 5'8" puertorican man what is my corect weight
Check an online weight versus height calculator, and they say that you are ideal at 73 kg, for a large frame, 68 kg for a medium frame, or 64 kg for a small frame. Check for your ideal frame size. Your age has nothing to do with ideal weight.
2answers
I am age 73 , female and my BP runs 132/67 is this normal?
120/80 is the so called average or normal. Yours looks reasonable for your age. Unless one of your readings surpasses 140/90 you should be fine.
3answers
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
1helpful
I want to see how much front spring sag on a 1994 Chevy C-1500 Std. Cab. 4.3 engine I can't find factory sepcs.
The short wheelbase C1500 is 194.1 inches long, 76.4 inches wide (plus one-half inch for Sportsides/Widesides) and 70.4 inches tall. The long wheelbase adds 18.8 inches of length for a total of 212.9. The K1500 measures the same but rides a little higher at 73.8 inches, or 74.3 inches for the heavy-duty diesel. The C2500 has a height of 73 inches, while the K2500's height is 74.3 inches and the K3500 is 76 inches tall. Length and width figures for the 2500 and 3500 regular cabs are similar to the 1500 series at 212.9 inches and 76.4 inches, respectively. The extended cab with standard box measures 236.9 inches long. The K3500 extended cab with long box measures 255.7 inches.
Read more: 88-91 GM Truck Frame Specs ' eHow.com http://www.ehow.com/list_7652650_8891-gm-truck-frame-specs.html#ixzz2KV8LFrLG
2answers
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
How to become tall?im only 4'9
Hello. Since you did not indicate your age let me say that you may continue to grow taller well into your 20's. If you are already 30 or older you probably will not get taller but count your blessings. Height is only a number.
Seat height
Height requirement
should not be jammed and neck with head supported.
Top Baseball & Softball Experts
Kardoc
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Baseball and Softball Expert? Answer questions, earn points and help others
