Toro& Electric String Trimmer Logo
A
Anonymous Posted on Jun 28, 2014
Return the head to trimmer position - Toro& Electric String Trimmer
1helpful
I have a brand new Bolens BL110 Curved Shaft String Trimmer and the cutting head won't stay on. Can I fix it or do I have to return it?
Make sure you have the head correctly located and affixed. If you have, return it.
BOLENS BL110 OPERATOR'S MANUAL Pdf Download ...
https://www.manualslib.com > ... > Trimmer > BL110
Summary of Contents for Bolens BL110. Page 1 BL110 2-Cycle Trimmer Operator's Manual Removing Unit From Carton Assemble The Unit No Tools Required!
Apr 05, 2021 • Garden
Craftsman 25cc straight shaft trimmer, severe head wobble
Try returning to SEARS they honor most of there purchases unless they suspect abuse! You could leave with a new one. Please leave feedback.
What would make the primer bulb stick and not return to normal position
Dirt and dust usually - but sometime the heat from the engine and sometime the heat from the elements cause it - you can take the gas cap off and push it - it should pop out or get a Phillips screwdriver and just remove it and pop it out clean it and put it back on the unit
2helpful
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 • Garden
How do i change from trimmer to edger?
I know that on Black and Decker there is a button down on the head near where the shaft enters that when depressed will allow the operator to rotate the head to a new position 90 degrees away from start position. On my Craftsman, the joint between the power unit and the driven unit there is a little pushbutton that allows the head to be oriented in four different directions.
Mine is brand new and stall when I give gas. Can I loosin the shaft that spins the head?
If this is a new machine, there is a factory warranty on it. You can't loosen the shaft that spins the head, but you can remove the cable or shaft that drive it. See about returning this unit under warranty terms maybe.
Poulan TE475Y motor upside down
No not that I have heard of
Sounds like assembled wrong to me
if you haven't already done so there should be 2 or 4 allen head screws on the housing squeezing pressure on the shaft you be able to loosen these screws and turn the shaft tube into the correct position and then retighten the allen head screws
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
The trimmer head on my Black and Decker cordless trimmer/edger seems to fall a few mm and the won't spin unless I push it back up the shaft. This is the second time I've had this happen in a unit after...
You probably have lost your return spring which will hold the head tight to the trimmer.Check to see if you have lost the spring. I would suggest looking on-line for a exploded view with parts list to see if you have any parts missing including the spring I mentioned first!
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
