Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Both green lights keeps flashing vienna super-automatica
SOURCE:
SOURCE: grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Posted on Nov 15, 2007
mirran
  • 515 Answers
SOURCE: can't make coffee
Try to open the steam knob and make a cup of water.
Posted on Jul 11, 2008
SOURCE: Manual for Saeco Vienna Super Automatica machine
Here is a link to the manual
www.powner.name/vienna.pdf
Posted on Jan 04, 2009
  • 1089 Answers
SOURCE: vienna automatica saeco will not turn on
If you push the power button and the machine will not turn on and it a newer machine there is a reset button on the side of the boiler that needs to be pushed. This will get you [power again. If the machine is older than 3 years you probably need a new board or power filter.
Posted on May 21, 2009
espressonist
  • 1711 Answers
SOURCE: How do I change the aqua filter in the Saeco
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Posted on Feb 17, 2010
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
How do I change the aqua filter in the Saeco Vienna Automatica machine?
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Vienna automatica saeco will not turn on
Apr 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
Can't make coffee
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
Grinder setting i
Oct 22, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
455 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
