SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
SOURCE: Need a manual for G.E.
I forgot to remove the 'moving rod' before running my machine. It makes a lot of noise now. Have I ruined it or can it be fixed?
SOURCE: residue left on clothes from no agitator top load GE washer
Do you use liquid laundry detergent & liquid fabric softener? If you do then this could be the source of the residue that is getting on your clothes. Over a period of time the gummy residue from liquids will accumulate between the tubs. You can clean out the washer with a product called Washer Magic or the unit will need to be disassembled & cleaned thoroughly by hand. Do not let raw liquid detergent or fabric softener come into contact with your clothes.
Also, here is a link to the agitator cap if you should need it.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
