Duo therm heat pump
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the RC terminal on the thermostat.
c. Connect the YELLOW wire from the air conditioner
to the Y terminal on the thermostat.
d. Connect the BLUE wire from the air conditioner
to the H terminal on the thermostat.
e. Connect the ORANGE wire from the air conditioner
to the G terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
SOURCE: We have a duo therm rv analog thermostat. When we
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
SOURCE: looking for wiring diagram for a duo therm by
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
