Question about Xact Communication X32X-2 2-Way Radio
I need a owners manual for xact x32x-2 frs /gmrs wristwatch radio
Need owners manual for x32x-2
2 Suggested Answers
SOURCE:
SOURCE: I need an Owners Manual for these 2-way FRS/GMRS,
i have 2way marlboro watch walkie talkie. I can figure out these thiings. it didnt come with a manual missy
Posted on Dec 31, 2010
How do i know if my xact communication two-way wristwatch is charging
I can't seem to find the manual online, but you could pose the question at Customer Support... http://www.xactllc.com/customer-support/
Jul 19, 2014 | Xact Communication X32X-2 2-Way Radio
How can I get a new AC adapter that is compatible with the Xact X32X-2 Radio?
The only thing you can do is contact the company that makes this product. It might be cheaper to purchase a new pair of radios complete with chargers.
Jul 01, 2014 | Xact Communication X32X-2 2-Way Radio
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
I need battery replacement for model x32x-2 where to buy?
Not worth the purchase price of batteries. Can buy similar radios for cost of new batteries
Sep 28, 2011 | Xact Communication X32X-2 2-Way Radio
HOW DO YOU TURN ON XACT 2-WAY RADIO?
First make sure it is charged then press and hold the power swich for about 2~3 seconds do not let go right away as the first of power up will put you in the time set /program mode.
Hutch
Jan 27, 2011 | Xact Communication 22 CHANNEL FRS/GMRS...
Cannot charge the battery for a xact model x2x
You will need to run a wake up charge into the battery. The best way to do this is with a 6v lantern battery with 2 wire leads just put + to + and - to - by tickling the contact plates on the battery (do not hold the wires on for more than 3~5 seconds. two times should do the trick ,then put the battery back in and right back on the xact charger plug and it should start to accept the charge.I just did 4 of them that were out of use for 5 years and all came right back to life.
Hutch
Dec 30, 2009 | Xact Communication 22 CHANNEL FRS/GMRS...
Xact Communication X32X-2 2-Way Radio Logo
134 people viewed this question
Top Xact Communication Radio Communications Experts
eradiostore
eradiostore
ka4iup
ka4iup
phgentry
phgentry
Level 1 Expert
Are you a Xact Communication Radio Communication Expert? Answer questions, earn points and help others
