your player is not compatible on file you save..or maybe you did not ininstall a cd for sound drive.. you can download soud drive online seach in yahoo or google.
Check that your CF card is NOT biggerr than the unit allows... read the specs. A lot of equipment is having trouble with the larger memory cards. Unfortunately the smaller ones are almost non-existent.
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to
erase the harddisk goto either the load or save screen and then choose
utility - there you will find the option to format the hdd.
you
can also format the drive (or any inserted compact flash-card) from your
computer thru the usb connection, but it is recommended to use the
internal format because the mpc can be a little picky when you format it
from the outside.
at first i would check if there is any folder
or the internal memory is set to autoload and just turn that of or point
it to another folder of you choice. that way you can keep the factory
delivered sounds. maybe you want to use them later, even if it is just
to explore the mpc. the factory sounds can be also downloaded later, but
be advised that there are different iterations of the stock sounds,
depending on whether your mpc shiped with a 32 or 128mb compact flash
card.
also the mpc os is not on the harddrive but in the internal
memory. to check the version hit mode-> pad10. latest official
version is os 1.24. if your main srceen looks different than in the
manual check double and triple before you do anything, because the
previous owner might have installed the third party jj os which comes in
different versions. some of them cost a lot of money! if you find this
check the other forum here for the alternative os.
i tried everything to import my rap beat into my tascam 2488 neo it wont let me says that i want a anotrher cd
how do i know which cd to put the wave file in cuz all i did were convert the beat into wave file in itunes and burn it as data on the cd and it wont do it i also burn it as music on the cd it wont do it what do i do?
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
Not sure if this basic instruction is what you are looking for or not, as I'm not sure how long you've been using the Akai Sampler. So forgive me if this is too basic and you're having a real problem other than one that assumes you are fairly new to the unit. Here goes:
To change the file format (or type of save) the MPC will perform a save in, you need to access the Save Screen:
Hold SHIFT and press LOAD (3 on the numeric keypad) to enter the Disk mode. Press SAVE [F2] to display the save screen. You then need to select the Type: - if it is only saving midi then the type will be "Save a Sequence" on this screen. You can change it to "Save All Sequences & Songs" if that is what you are referring to as 'the normal way'.
First ensure that you are saving into the right folder, on MPC HD and not into a subfolder, and that files are in correct midi format. Also ensure that connections to MPC are OK.
If connections and saved files are ok, then probably you need to reinstall Mpc 500software onto your computer, using disk provided with your Mpc 500.
If your songs are already in mp3 format than they must have been probably saved in 256 or 320 kbps. That is a waste of space since human ear can't tell the difference between anything higher than 192 kbps. For mp3 player it is more than enough to save songs with 128 kbps, especially if you're only using headphones. If the song takes approximately 4000 KB than you could fit close to 500 songs on 2GB mp3 player like yours. So, you need to check the beat rate of the songs and make convert those with beat rate over 192 to 192 or 128 which is just fine.
When you format memory, first folder is created eg "dsc0001", first 500 images are stored here. Take more images, new folder "dsc0002" is created, second 500 images stored here.
