Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
You probably need to set the time zone. Hit the set button until it shows the time zone (ie -7 MST), then hit the "+" button until it shows your time zone and the correct time. Continue hitting the set button to cycle through to the end of the settings.
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Press set button repeatedly -you get timezone mode
and change your wished time zone and select your zone
then press set button to normal mode and adjust the current time.
kindly gave your rating after you read this.
Each time you press the set button on the back it selects one of the items that you can set. For example if the "month" is selected by pressing the "set" button then press the "+" key to change it from 1->2->3->4 etc. Each time you press "+" key the month will go up by one. Stop when you reach the correct month. You can do the same for each item including the time zone and daylight savings time and whether you want your temperature to be in Celcius or Farenheit. Hope this helps...
