Jabra BT2020 Bluetooth Headset Logo
B
Baron Blake Posted on Jun 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHY IS MY HEADSET NOT CHARGING - Jabra BT2020 Bluetooth Headset
Argospete
Level 3:
Genius:
  • Master 1,035 Answers
  • Posted on Jun 29, 2014
Argospete
Master
Level 3:
Genius:
Answers
1035
Questions
Helped
223367
Points
2731
Possibly batts need changing/replaced. they do wear out
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
1helpful
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
8helpful
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
2helpful
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
2helpful
Headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
7. If this procedure does not resolve your issue to try a system reset.
10helpful
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
To Re-Subscribe:
2helpful
2answers
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
5helpful
2answers
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
