Question about Dishwashers
Samsung flashing heavy - Dishwashers
  • 56 Answers
If you have an owners manual
and see if there is an explanation.
If not, go on line and Google it.
Posted on Jun 28, 2014
SOURCE:
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Why on the Samsung DTM400 series dishwasher are normal heavy and smart/auto lights all flashing?
That's a High-temp Heating Error. It's usually caused by a bad ECS sensor. You will need to call a professional repairman to replace it. (I recommend Sears).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 17, 2014 | Samsung Dishwashers
Normal, heavy, delicate lights stuck on--cant power on or off
If you have tried to unplug from mains power and there is no difference then you will need to provide the actual model number of your dishwasher in comments field.
The Samsung error codes for Normal, Heavy , Delicate lights stuck is not listed. The closest is Normal, Heavy, Quick which relates to a Low Water level. Also confirm which lights are stuck in your case and whether these are flashing or not.
Apr 17, 2014 | Samsung Dishwashers
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DMT400RHS Builtin Dishwasher
Samsung DTM300 Normal Heavy and Quick lights flashing
Our Samsung has the touch surface on the top edge of the door, no mechanical buttons, and we kept getting errors like that. Took me a while to realize that those buttons work by capacitance like a touch screen phone, and that my IKEA countertop had a metal heat/steam shield which was close enough to the door to essentially 'push' the buttons and turn our washer off. We solved the problem by applying a vinyl bumper sticker over the heat shild to prevent the metal from conducting a signal. BOO YA, BOYEEE!!
May 01, 2012 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
