I have connected my mobile phone erricson w995 with the usb to my apple mac but no pictures
Try connecting the phone to a different laptop; preferably a Windows one to see if that succeeds. The Sony website doesn't list any Apple MacOS drivers, so not sure if it will ever work.
Installing the drivers from: http://www.driverscape.com/download/sony-ericsson-w995 onto a Windows PC should let you download the pictures to that PC without any problem.
Good luck !
SOURCE: Using intenet by conecting the Sony ericsson K750i
can someone tell me how to get my k750i to work with my acer laptop as i would like to use my phone as a wirless connection. Step by step please
ozzieboo :)
SOURCE: My computer does not recognizing Sony erricson w580i's usb port.
turn off the phone and turn it back on, and if that doesnt help, try a few more times and then hit it a few times, and if that doesnt work, plug it in for the charger for a couple seconds and then it should work. It always happens to me, its getting annoying. also, make sure that the memory card is in it and it registers.
SOURCE: no network coverage (sony ericsson w995)
did you hit your phone?
try making 'Master Reset' (settings->master reset).if this doesn't work try flashing phone's firmware
SOURCE: transfer contacts with an inactive smartchip
Since you say that your computer can read your memory card, you could try puting a sim into your phone temporarily and then backing up your contacts onto your memory card...sony ericsson phones do provide you with that option.The procedure is: Phonebook--options--more--advanced--back up to memory card. Hope it helps, Rushil
SOURCE: Sony erricson w705, wont charge the battery, it
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
U need to install motorola phone tool software(Comes along with mobile) in ur computer after install that software u will get an icon on desktop of motorola phone tool then when u will plug in data cable with mobile and computer u will get a picture of ur mobile on ur computer after open Motorola phone tool icon from ur desktop
Gizmo1
