DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
A
Anonymous Posted on Jun 28, 2014
Descale eam3400 delonghi magnifica machine
How do I descale my delonghi magnifica eam 3400 coffee machine?
Brian Coughlan
Level 2:
Champion:
  • Expert 280 Answers
  • Posted on Jun 29, 2014
Brian Coughlan
Expert
Level 2:
Champion:
Answers
280
Questions
0
Helped
87085
Points
430
Get hold of some good descaling solution follow the instructions on the label, normally you pour it into your reservour & run it through the system raw, no ingedients but do follow the manufacturures instructions.
NoName Jack
Level 3:
  • Master 1,150 Answers
NoName Jack
Master
Level 3:
Answers
1150
Questions
Helped
232897
Points
4657
Get a bottle of DeScaling solution from your dealer or on line.
Empty the water container and top up with descaling solution.
Put a cup under the steam outlet.
Click the Menu button till you see descale. Then start the descale sequence. The solution will clean the calcium out of the internal pipes. Run the program a couple of times depending on how classified the pipes are. When finished, flush the machine with fresh demineralised water a couple of times before making your next coffee.
If in doubt, read the manual or get a copy of the manual as a pdf file from on line.
It's all pretty straight forward really. Your just pumping a cleaning solution through instead of water.
Good Luck
dziustas1
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Jun 28, 2014
dziustas1
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
13846
Points
28
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
1 Related Answer
Anonymous
  • 544 Answers
  • Posted on Mar 21, 2009
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
How to descale the DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
put your descale mixture in 1 litre water in your water tank on coffee machine set machine on descale then after finish, put 1 litre clean water for rinsing. the all ready for coffee.
2helpful
How do you descale the machine,as we have no manual
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
2helpful
How to descale the delonghi icona pump coffee machine?
1helpful
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
3helpful
3answers
Where can I get the parts for delonghi magnifica eam-3400.n
Howdy:) You can get parts and accessories for your Magnifica here: http://www.delonghiusa.com/index.php?texts&pid=15
Hope you are up and espressing asap:)
2answers
Delonghi magnifica eam 3200 won't descale
thanks,
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
