How do I fix Android Huawei Ascend phone? It's stuck on the start-up screen.
I nearly dropped phone, caught it before it fell but the jolting motion must have screwed up something internally. It powers on but keeps recycling the start-up screen.
Re: How do I fix Android Huawei Ascend phone? It's stuck...
You can recover your phone by holding down a sequence off buttons when you switch it on and it will go into recovery mode and there you can factory reset it to fix it
This can happen for a number of reasons. You could have a virus on the device, the operating system could be crashed, there could be a hardware glitch.
I would start with attempting to boot the phone into recovery mode. You can follow the steps attached to do so. Once you get into recovery mode, try to select the option that says "Clean System Cache" and then reboot the phone.
http://sim-unlock.net/simlock/Huawei/Y330 How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Open the board, clean it with home dry cleaner, apply flux soldering paste, and fron the opposite side, apply hot air while fixing the switch in position. We'll done boss.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
