Sony Cyber-shot  DSC-W80 Digital Camera Logo
A
Anonymous Posted on Jun 28, 2014
When i turn on my sony cybershot dsc-w80 power light comes on but screen is black why?
5 Related Answers
Anonymous
  • Posted on Aug 29, 2008
SOURCE: my sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
AMJAD HUSSAIN
  • 586 Answers
  • Posted on Mar 11, 2009
SOURCE: sony cybershot dsc t3
   For all of you who have commen problem in your cameras, That this problem is caused malfunctioning of CCD IMAGER and SONY repair it free of coast. For free of cost replacement of CCD IMAGER please visit your nearest SONY SERVICE CENTERS.
Thanks for using FIXYA!
Take care.
Anonymous
  • 43 Answers
  • Posted on Aug 18, 2009
SOURCE: I have a sony dsc-w80 that won't turn on. I
you have a bad power switch, you will need to take the camera apart and clean the inside of the switch with alcohol
Anonymous
  • 4090 Answers
  • Posted on Sep 28, 2009
SOURCE: Sony Cybershot dsc-w110 won't turn on ?
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thyanks for usi9ng FIXYA
Testimonial: "Thanks Man.... But before going for compressed air, I blew out some Air from Mouth, and then slapped it against my palm,It Worked,Thanks Man :) ThankU"
Anonymous
  • 4090 Answers
  • Posted on Mar 24, 2010
SOURCE: What is the answer to the problem
is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
Please rate my help++++Thanks for using FIXYA
Hi! I need help, my Sony Cybershot S600 suddenly stopped working, the screen is black.
Question edited for clarity and toss in some CAPS.
Question moved to model category.
They normally need dealer service.
https://www.google.com/search?q=sony+cybershot+s600+black+screen
1helpful
2answers
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
2helpful
When I turn the camera on it has a playback but you cannot view moving images, the color is black on the screen and the camera says, turn the power off and on again, when I follows what the camera says, it...
I already solved the problem by searching at the internet, in this link http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscp200_question.html?qid=3653 by tapping my camera I solved the problem.
E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
Cracked LCD screen for sony cybershot dsc-w80
I LOCATED A REPAIR COMPANY THAT WILL REPLACE YOUR LCD. I DO NOT ENDORSE ANY REPAIR COMPANIES, BUT PROVIDE THEM AS A SERVICE ONLY. THE COMPANY GAVE A QUOTE OF $79.00 PLUS $12.00 SHIPPING. I ALSO LOCATED USED LCD SCREENS ON EBAY.COM, THAT WERE AVAILABLE FOR A BUY IT NOW OPTION FOR MUCH LESS IF YOU FEEL YOU COULD CHANGE THIS YOURSELF. FROM WHAT I HAVE BEEN ABLE TO FIND OUT IT ISN'T SUPPOSED TO BE VERY DIFFICULT. I WILL LIST THE REPAIR SHOP BELOW. HOPE THIS SOLVES YOUR PROBLEM! IF YOU NEED MORE HELP,REPLY TO: ARCLIGHT1217.
www.precisionCamera.com
eBay.com
Cybershot DSC W80
Can you please send me copy of dsc w80 software cd - if its too large to email, zip and store at mediafire.com or other file storage site.
THANKS!
2helpful
5answers
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
