LG 22" FLATRON LCD Monitor Logo
A
Anonymous Posted on Jun 27, 2014
Lg flatron w2252tq - LG 22" FLATRON LCD Monitor
5 Related Answers
Anonymous
  • Posted on May 29, 2009
SOURCE: Flatron W2252TQ goes into 'power saving mode'
I had a similar problem with an LG monitor that I resolved by connecting the analogue cable as well as the digital cable from the pc. This problem must be caused by the monitor not receiving a digital signal.
Anonymous
  • 532 Answers
  • Posted on Nov 29, 2009
SOURCE: lg flatron w2252tq screen says analog power
There should be a menu button on the monitor to change it to digital. It should be labeled source. It should be on the front second from the right.
Anonymous
  • Posted on Feb 11, 2010
SOURCE: how can i get or find driver for lg flatron
Have you tried manufacturers web site?
Anonymous
  • 75 Answers
  • Posted on May 01, 2010
SOURCE: monitor will not stay on
First of all check your mains lead make sure it is not fused. then check the lead from the monitor to the computer make sure it is connected ok then check your video card You can try connecting the monitor to another computer to see if it works on that one
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 01, 2010
SOURCE: flatron monitors w2252tq how to hook up speakers
Here the user manual:
http://www.generalmanual.com/Monitors/LG-W2252TQ-Widescreen-LCD-Monitor.htm
Or: http://www.retrevo.com/support/LG-W2252TQ-Monitors-manual/id/19697ci559/t/2/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
How to turn on the sound or is there any audio jack on the monitor?
Hi Luisa
This monitor does not have sound capability, please download the manual using the link below:
http://www.lg.com/us/support-product/lg-W2252TQ-TF#
Andrew
Lg flatron screen keeps flickering, if i switch it off and on its fine then its starts again.
sounds like a capacitor in the power supply is going. Check caps and look for bulged or leaking component. Most new devices have non filled caps so you may not be able to judge these by a visual check.
Flatron w2252tq
Hello Shan,
The W2252tq uses the AIP-0165 power supply board that is also used in the L227Wtg series LG series monitor. This board is known to have issues with the filter capacitors going out. When they go out it causes the monitor to not power up just lie you have. Here is a picture of the power supply board in the unit and below is a link to a repair guide for the L227Wtg, since it has the same power supply the repair guide for the board will be the same.
Here is the repair guide.
http://www.ccl-la.com/blog/index.php/repairing-a-lg-l227wtg-pf-22-monitor-no-power/
Open lg 22' wide screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
2helpful
Lg flatron w2252tq screen says analog power saving mode. HELP!
1helpful
LG Flatron W2252TQ 22'' monitor not working in digital mode
try to set your screen resolution to maximum using Display Settings in windows. Besides, are all software drivers for this monitor loaded and properly installed? Right click My Computer=>Properties. select hardware => device manager. Make sure video icons are not marked with question marks. if they are, install monitor drivers shipped with your monitor.
regards!
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
