Car sputters when acelerating
Possible causes are:
-water in the fuel: fill it up at a different place, or if the tank is already mostly full, buy a bottle of water remover ("dry gas") at an auto parts store and add it to the tank
-dirty injectors: if this started gradually, there may be crud on your injectors. Buy a bottle of injector cleaner at an auto parts store and add it to the tank
-lack of spark: If neither of those solve it, you've got a problem with the spark plugs (less likely), spark plug wires (more likely) or ignition coil. Replace the plugs and wires, they're due on a car that age if they haven't been done. If that doesn't fix it, you need a new ignition coil.
