Dryers Logo
A
Anonymous Posted on Jun 28, 2014
How to get the error code test on Frigidaire affinity model FARE1011MW
Having an issue with the Frigidaire affinity model FARE1011MW dryer, the dryer will not start. will beep when start button is pressed then the drying light will start blinking.
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 03, 2014
Fixya Pro
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289691
Points
2557
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 24, 2008
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Anonymous
  • Posted on Sep 27, 2008
SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Mar 13, 2009
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Anonymous
  • Posted on Jun 22, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Anonymous
  • 1531 Answers
  • Posted on Sep 17, 2009
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
2answers
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
1helpful
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
Dryer will not start the led light are off
Hi maike, this is AP!
Often when a product does not start I would recommend starting with the power source such as the breaker feeding power to the dryer. There are two house fuses that supply voltage to the dryer circuit in your fuse box. Check and replace the fuse in the fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the dryer may turn but will not heat.
For your particular Frigidaire dryer, model FARE1011MW, if the power source is not the culprit the control board could be defective. Another source of the malfunction could be the door switch, however I would think you would have power to the control panel if that was the case. If your appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information helps to some degree.
Thanks,
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
