The troubleshooting section of my manual gives a Generic fix for F codes other than F20,F21,F22 as "Select stop twice to cancel the cycle.Select DRAIN & SPIN if there is excess water in the washer. Re-select cycle and press START If problem remains, call for service."
Not much help! Try checking the inflow by removing the hose to see if there is any debris in the inlet (rust etc.) Also could be a balance issue. Rearrange load and restart the cycle.
Or it could also be a leveling issue. Use a level to see if it needs to be raised or lowered by turning one or more of the "feet" with a crescent wrench to level the unit.
SOURCE: error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
SOURCE: Kenmore Elite H3 error code F11
F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
go 2 repair clinic on line, same codes for whirlpool duet repair help then error code tab
SOURCE: Sears Kenmore HE3 Error Code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: stops on spin cycle and gives a f11 error code
The F11 code is caused by either a CCU failure or an MCU failure...here\'s how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it\'s most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...
