Is there an instruction manual for a sigma 50mm f/2.8 EX macro lens for a Nikon mount?
Chuck, sorry for the late response. Last days I had to work through several hundred anonymous questions. Most irrelevant and not complete, so I could not answer most of them, but I had to read them all.
Sigma, does not have a service, where you can download a manual. But the manuals from Nikon, most of the time don't tell anything about how to use the lens.
I found a page with all specs. The link is down here.
I have to guess why you did put the question here in the first place. I think because you have a Nikon camera without a focus motor. Like a D3x00 or the D5x00 or a D40 or D60. (for the x you can add 0 1 2 or 3)
If you have one of these camera's the lens can't be used with auto focus You only can use the lens in manual focus. Most other camera's from Nikon, like D80 D90 D7000 D300 and more expensive, all do have a focus motor and can work with this lens in full automatic focus mode.
50mm F2 8 EX DG Macro
SOURCE: trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature) Capable of macro photography, this
lens has a 1:2 maximum close-up magnification at the 300 mm focal
length. It's the ideal high performance lens for portraits, sports
photography, nature photography, and other types of photography that
frequently use the telephoto range. It also has a switch for changeover
to macro photography at focal lengths between 200mm and 300mm with a
maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing
distance is 1.5m / 59 in. at all zoom settings.
SOURCE: Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5)
Non-CPU: Can be used in mode M, but exposure meter does not function;
electronic range finder can be used if maximum aperture is f/5.6 or
faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
SOURCE: lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
SOURCE: I need an online/digital manual for a 24-70 F2.8
Well you can please follow the below link to get your manual (you just make contact to sigma and ask them for the manuals they will send you the manual, there are no digital manual available on net) -
http://www.sigmaphoto.com/contact/contact.asp
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
