SOURCE: Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604
Monday – Friday
8am – 8pm EST
good luck with this.
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
SOURCE: delonghi PAC F10 air conditioner doesn't seem to be cooling
It could well be low on refrigerant, as well as a multitude of other possibilities. I'd have it serviced by a pro.
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
