Question about Kaz V4500 Humidifier
HOW TO CLEAN A V4450? - Kaz V4500 Humidifier
  • 2,013 Answers
You can download the manual here... http://www.manualslib.com/manual/706474/Vicks-V4450.html
Posted on Jun 27, 2014
SOURCE:
Reset clean light
clean ligth its means still have dirt in filter or any,,,just clean and its will goes by its self,,
if not try to off an on again,but still the same,,its means the sensor need to replace,call for the service technician,dont waste time and money if you dont have any idea for the repair
Oct 26, 2013 | Honeywell Humidifiers
Good why to clean caluim build up on my humidifer
Avoid CLR!!! Destroyed my heating element! Try soaking in pain vinigar for a while, then use an old toothbrush to gently scrub the calcium off. may take several times to get it all off if lots of buildup. After it's clean, try cleaning once a month to make it easier to clean instead of letting it go for so long it takes all day to clean. ;)
Apr 13, 2013 | Crane Cat EE-3187 1 Gallon Humidifier
No manual how do i clean a kaz vicks humidifer model v4450
http://www.ehow.com/how_7442829_clean-vicks-humidifier-model-v4450.html
Jan 21, 2011 | Kaz V4500 Humidifier
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
Changed filter and it still says "clean filter" on the gauge-?reset button
not sure if there is a reset button if not
I would say if the filter was bad enough some of the foreign materials (particles the filter should capture) may have went on down the line.
the "clean filter" indicator is most likely activated by the volume of flow. So when the filter is full the flow is reduced in turn the "clean filter" comes on.
so if filter has been replaced and there is no reset button try backflushing the lines. If the lines have built up blockage your flow will stay low and the "clean filter" will stay on.
on these lines there may be bends and turns most likely to have build up in these areas restricting your flow
clean lines (low air pressure may work easiest)
Mar 03, 2010 | Sunbeam 1117 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Kaz V4500 Humidifier Logo
317 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
