Check for the switching pulse at the coil input terminal. It should be less than the battery voltage but not zero, or pulsing in sync with the engine (if you know the spark dwell angle, you can calculate the voltage by multiplying it by the number of cylinders, dividing by 360 degrees, then multiplying by the battery voltage). If you don't get any indication that the coil is being switched to ground to generate the spark, your distributor contact (for mechanical ignition switches) , magneto or electronic ignition module could be the problem. Before changing whatever one of these you have, double-check the wiring to the coil - a misplaced, broken or loose wire will have the same effect.
