Getting error message "*memory rx* 2P Recording Paper Jam I can't find any paper jammed anywhere - suggestions???
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
SOURCE: Minolta 2350DL laser printer paper jam that will not clear
You have to take off the roller . :)
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
SOURCE: paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
SOURCE: code 1039
COF 33 ATDC sensor problem
1039 -communication error for remedial this code turn OFF and ON the power.
