SOURCE: Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
SOURCE: air conditioner compressor will not shut off.
Remove the cover on the outside unit that covers the circuit board and contactor and capacitor. Then start the unit and set the thermostat so that the unit cuts off. Then go back to the outside unit and see if the contactor is still pulled in and the unit is running. Next open the breaker and see if the contactor drops out. If it doesn't your contactor could be stuck. Try to free it or replace it. If not the problem could be in the circuit board.
Testimonial: "contacter was welded shut. replaced contacter.working good now."
