The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
SOURCE: error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
SOURCE: FLASHING EXCLAMATION POINT
Link to the manual: http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Basically it only means that the printer needs attention.
I would check for a paper jam or misfeed, out of paper, low or empty toner.
SOURCE: Will not print. Orange exclamation
You may follow Dell's preventive maintenance on the printer you have, the orange exclamation mark regulatly mean a hault on the printer's operation. The link will show you have to have it cleared and make the printer operational once again.
Dell's preventive maintenance for printers.
SOURCE: I have a HP LaserJet 1320n printer and it will not
Possible Solution to your issue!
Blinking Attention Light
HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
SOURCE: hp printer model M1522nf displaying permanent
HI,
This a formatter failure, sounds like the formatter went out while trying to do a hard reset or after updating the firmware,
Try doing a nvram:
Turn the printer off and hold the down arrow and the cancel button
Turn the printer on while holding the two buttons down
Continue holding until you see the permanent storage message and wait for the ready message to display
If this doesn't work call hp and tell them that printer is frozen and will not initialize, this is due to a formatter failure. If it has been less than 2 years since the purchase date then you will apply for a service note and will be able to have the printer serviced for free, Contact hp's tech support at 1800-334-5144.
Al
