My gas range now beeps like an alarm clock and displays f1 and f2. I can turn on the burners but not the oven since it's an electronic lcd panel for controlling the oven and other features. Is it time for a new stove or can a repairman fix it?
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0 & F1
EOC (Electronic Oven Control) failure
Replace Electronic Oven Control
F2
Oven too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
F4
Oven temperature sensor shorted
Replace oven temperature sensor
F5, 6, 7
F8
Lock switches
Check switches and replace if necessary
I HAVE TRIED IT SEVERAL TIMES AND NOW I AM ALSO GETTING AN F3. WHAT DO I NEED TO DO?
I have a Kenmore elite gas range model# 79075903990. Approximately, 3-4 years ago I had to replace the Electronic oven control, everything worked fine until recently. I recently saw an F1 error message, it beeps, then F1 again. Do I need to replace EOC again or other possible solutions?
Our oven beeps like an alarm clock any time of the day/night constantly displaying F1. We got up about six times in the middle of the night. What do we have to do wo fix it??
the stove beeped I got code 11 then hit clear then code 90 door locked control panel for oven will not work
