I just replaced the sensor sheet on the inside and put it back together and there is no lcd panel lights or power. also only the strobe light and play. the rest of the light are off but it will spin
SOURCE: technics 1200sl pitch control
There seems to be 2 issues with this unit. Usually when the platter speeds up very quickly, one of the IC (integrated circuits) are faulty and needs to be replaced. However, I've never seen the 33/45 lights come on in addition. So, perhaps the issue started with faulty 33/45 switches, and it then caused a short to one of the IC's.
This will have to be professionally serviced, as it is not an easy fix. There are various circuits on the main board which control the drive, so it's a matter of diagnosing which is the culprit. The 33/45 switches will also need to be tested/replaced.
- TERMiNAL OPTiC
www.DJPROLAB.com
SOURCE: Technics SL-DZ 1200
Upgrade the firmware. you need a small SD card.
I forget what keys to hold down at power up.. or where to download the update
BUT.. it may work.. I am sure you can find it..
Or maybe you have gunk on the tracking servo's gears "linear' a grain of grit.
working on the DZ is easy if you have any electronics background.
SOURCE: User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
