Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
A
Anonymous Posted on Jun 27, 2014
Frigidaire model glgt1041as2... serial xe34400285 washer/dryer combo
Leaking water on floor not coming from hose connected to the hookups on wall. first time problem please help.
Jorgie the appliance guy
Level 3:
Top Expert:
  • Frigidaire Master 5,639 Answers
  • Posted on Mar 31, 2015
Frigidaire Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522138
Points
32630
Check ur water pump hoses and tub drain hose inside
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 07, 2007
SOURCE: HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
Anonymous
  • Posted on Nov 16, 2007
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Anonymous
  • 156 Answers
  • Posted on Mar 03, 2008
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Anonymous
  • 156 Answers
  • Posted on Mar 06, 2008
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Dec 09, 2008
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
1helpful
Why is water leaking from bottom of double stack fridgidaire washer/dryer combo?
Thank you for your post, friend!
From the information you have provided your Frigidaire laundry center is leaking water from the bottom after a day or so. It sounds like you have a slow leak and this could be in your drain line, drain pump, or gasket. I would advise you to review your gasket and drain hose to make sure there is no visible crack or wear that water could be leaking out of. If you do not see any apparent leaks it could be an issue internally and this is not a simply DIY job. You may need to request the assistance of a professional technician for proper disassembly of your laundry center. I hope this information has been helpful. -Matt
I have a frigidaire atf6000es and while the washer is running water is running out in the floor
Hello Brandy Neal - Often a leak coming from underneath the washer would indicate a leak possibly in the hoses or in the tub. If the hoses are securely tighten then at this point I personally recommend consulting with a certified technician to narrow down the precise issue.
There is a leak somewhere! I walked into the room while the washer and dryer were going and stepped into a little puddle of water. Upon closer inspection, I noticed water droplets on EVERYTHING in the...
to get water on the walls indicates that a hose from the taps to the back of the machine is loose or cracked allowing pressure to spray the walls
check all hoses and connections
2answers
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
2answers
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Washer and Dryer
there will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
1helpful
Frigidaire stackable will not stop filling with water or agitate.
is washer running over or just never filling? if running over suspect small hose to water level switch kinked off or a hole in it..if never filling suspect drain hose too low or no air gap between drain hose and stand pipe hose must catch air to break siphon
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
