HP Designjet T1300 Inkjet Large Format Printer - 44" - Color Logo
A
Anonymous Posted on Jun 26, 2014
WHAT CAUSES HP DESIGNJET t1300 ERROR 21.2:13?
matsak spiros
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • HP Expert 147 Answers
  • Posted on Apr 16, 2017
matsak spiros
HP Expert
Level 2:
New Friend:
Cheetah:
Answers
147
Questions
0
Helped
32317
Points
493
Hp t1300 hard reset pin garcias
hello Julio
its printer say printer and post to printers next time.
I dont do them but here goes, 15,000 printers are pain, to support.
HP DesignJet T1300 PostScript Printer read the manual yet,
most printers can be reset by unplugging from the wall
AC power, then hold power button down and plug in to wall now.
hold the button for 30 full seconds.
and release the botton (this is generic answer)
why ask here we are not HP.com
HP.com is HP.
https://support.hp.com/us-en/product/hp-designjet-t1300-postscript-printer/5053942/manuals
here is your set of manuals, RTM. it will cover this topic.
if you read.
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Designjet 63 03 error
In some cases the hp/gl2 card may cause this error just replace it
Printer error 21.1:03 what i di?
Service station Motor not working or not rotating
Take out carriage assembly from serve station area.(Power on printer wait till service station un lock carriage, switch off main power, take out carriage assembly from service station. If service station not releasing the carriage assembly, my sincere advise "call for service personnel")
Remove right cover,check service station motor connector,connectivity cables,if no damage found,remove service station, check any paper particles jammed inside?any obstructions?any gear damage?.. shoot the problem, other wise replace service station..
This activity is advisable for the service personnel only.
5helpful
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
