SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
SOURCE: Low pressure water dispensing on an LG brand fridge
First check the pressure into the frig. Sometimes the inlet line can get kinked. The second thing I would buy is a NEW water valve. There only about $20-$30, and not too hard to install. A nut driver and a pair of plyers should be the only tools needed. There are usually 2 water valves, one for the water, and the other for the ice maker. If 1 is bad... the other is next to fail soon, so buy both before to save head aches down the road.
