SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: how do i set up a scan box on my konica
Konica has a free program called PageScope Box Operator. You can download it from Konica's Web Site or it comes on the disk you should have gotten when you got the machine. Install it and from there you can pull up your scanned documents and you can create boxes. Plus it keeps everyone from accessing the printers Web Utility.
SOURCE: change the transfer unit on a konica Minolta
open right door, remove 2 lock screws and pull out the tbu
SOURCE: konica minolta bizhub c252 error c-5351
C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
SOURCE: I have a Konica Minolta Bizhub c252 what is code c-5102
C-5102/5103 - Main motor failure.
Check the motor connector,the drive coupling or the mechanical control board and DC power supply unit.90% mechanical rpoblem.
