A
Anonymous Posted on Jun 26, 2014
C650 konica minolta1610f with service code c650
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 24, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913018
Points
11959
Scanner home position code. Check the scanner located under the big glass. the scanner also has the exposure lamp. the bright light.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1 Related Answer
Anonymous
  • 167 Answers
  • Posted on Feb 17, 2009
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Serial number need to be enterened KONICA C650
Notes:
1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
In this scenario, Initialization would then be necessary and support must be contacted.
Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
  • If i-Option was ever licensed on the MFP and if the additional 512MB of memory was ever installed at any time
  • The firmware level prior to the machine being upgraded to version 88 (bizhub C353 and bizhub C650 series models only)
  • If the machine ever had firmware version 85 or 86
  • A history of recent NVRAM or EEPROM board replacement
  • Obtain a machine Management List and have it ready to attach to the ticket.
  • A screenshot of the message returned from the LMS if "Repair" was unsuccessful
  • A "Request Code" from the MFP and the S/N must be obtained in order to start the "Initialization" procedure (see attached "Obtain Request Code" and "Initialize")
2. Make sure to enter the MFP Serial Number, Repair Demand Code and the Request Code in uppercase letters when entering data in License Management Server online.
3. Version 88 firmware refers to the bizhub C353 and bizhub C650 series models. Other models have the correct firmware from factory.
4. To view a PDF, you may need to download a free copy of Adobe Reader®.
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
How can i solve code C-2a02
https://www.tradebit.com/filedetail.php/257047557-konica-minolta-bizhub-c451-c550-c650-field
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
1helpful
What does the Error code C-225B means on the Konica Minolta?
I am unable to fix the problem C225B in Konica C450 please help me i have replaced all the tonner unit and Developer kit also.
Code erreur c3b04
what solution for the trouble code c-3B04 for c650
We keep getting the trouble code C 3822. We cannot
You likely can't fix this yourself. Konica does list a solution addressing this issue but it will require a firmware update to your machine. There may be other causes as well. First be sure you don't have any HVAC vents aimed at the machine (particularly the exit side of the machine) as this is a fuser temp related service code. Contact an authorized Konica Minolta dealership and ask if they can update your firmware for you.
2helpful
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
