I need to hear the beeps because I just built this pc today and it only powers up for one second and shuts off. All fans start spinning and LED lights on front of case come on but then it just shuts off. Have not even been able to install Windows 8.1 yet.
SOURCE: unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
SOURCE: 915PL-A2: no post, no beep, no keyboard lights
You may have a short between the board & the case. (check it).
Even if this means removing the board. That clicking you hear through the speakers suggest a short. Make sure your using (Stand offs) which keeps your board off the case's mounting surface. Check the back plate so the tabs are touching the ports comming off the board for good ground.
Double check the you have fully connected both the main power ATX_ 20 pin power connector & the auxiliary 4-pin power
connector. pg. 10. Connecting 20/24-pin power cable Remove & re-seat. If your PSU has a 20 pin connector make sure you connect the cable from the correct end.
Without POST you will not get video to load. Reset your bios
pg. 9 in your manual. Re-enter your bios and setup the bios settings for your board.
Let me know if this helps you reach POST?
SOURCE: Black screen and beeping.
try to use pci card to getto screen agp ect ok maby bios thinks its that output reset it pull out battery then back in
SOURCE: No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
SOURCE: pc can't boot up , no display , hdd led is constatly lighted
Check CMOS battery(Coin shaped battery), it should show 2.5-3V, if not then replace and check, you can even try and test the mbd without the CMOS battery. Some mbd does not boot with a faulty CMOS battery.
