SOURCE: how do i remove the faucet handles?
They make sockets for stems to break them loose from valve. It should have a place for a wrench to break it loose also.
SOURCE: The handle on my outdoor faucet is broken. I
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
SOURCE: Where does washer go for 12h-6h/c stem from Danco for faucet?
If it is red in color it is a #38 fiber washer and is the cap thread gasket.
