No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid.
Please check ''TANK FILL'' hose quick connector & ''LIQUID'' hose on ISV Tank & make sure both valves is opening properly.it sound like(one of those) close! If valves is Ok then check tank fill solenoid, it may need to rebuild or replace. If those are OK, replace ''TANK FILL'' Hose. I hope this will help you to solve the problem, if so please vote for it. Gool luck!
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
solenid valve may be faulty. to test disconect from the cold side and atch to the hot side, the solenid valve is an electronic valve that switched the water on and off its usally atched inside of the back of the machine where the hose attaches to.
