HEAT FAILURE - This means the heating system has failed to respond, which can occur because a high temperature limit switch has been tripped and needs resetting. On gas deep fryers, "HEAT FAILURE" may display if the pilot fails to light or if the pilot flame is too weak as detected by the ignition module.
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805 TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
The hi limit must be tripped. Open the door and find a swich that has a really small red button on it and push it in. If it clicks, it was tripped. If not, with the door open bend way down and look up whare the top of the door is when closed. You will find a small black fuse holder. Push up as you turn, and pull out. Check to see if the fuse is blown, if it is replace with the SAME SIZE & RATING. DO NOT USE TIN FOIL.
